Custom24
- Oxfordshire
I think I've broken a seal or something in my brake caliper.
One of the pistons was stuck and while trying to free it, I ended up causing a fluid leak (mineral oil in these). The bike hasn't been used in a while, which is why I think one of the pistons got stuck.
I was trying to use a toothbrush handle to give the piston something to press against, but it wasn't flat enough and now the stuck piston is out but at an angle, and oil leaks from it.
There was a snapping noise, but that may have been the plastic toothbrush handle (or the seal, I'm not sure)
Can the seals be repaired (by me) or is it a case of replacing the caliper? I've not tried taking the caliper apart yet. No harm in doing so now, I guess.
Thanks for advice
Mark
Thanks for advice
Mark
