BR-7070 Calipers
derrick
Got a problem with front hydraulic brake, have been on Shimano site cannot find information i need.
Got a bike with a BR-R7070 Caliper on the front, The BR-7070 comes either front or rear, does anyone know what the difference between the front and rear are.
The problem i am having is, i have good pressure on the lever but bike will not stop as it should, been through all incompatibility problems, STR 7025 lever, BH90 brake pipe silver inserts. shimano fluid.
I like Skol
A Minging Manc...
Contaminated pads/discs.
Kbrook
There’s no difference between the front and the rear other than the front comes with a little bock underneath to switch between 140/160 rotors. if you need a new one you can buy either and just remove the block from your old one via two bolts underneath.
Kbrook
Regarding the other matter if your discs were contaminated you would have noise, horrible noise, if that’s the case clean or replace. The obvious other thing would be it needs a bleed but that would lead to a spongy feel at the levers which you say you don’t have.
