As you can see, the top spacer is moving after assembly. I am pretty sure that top spacer is supposed to be quite firm.
Here are all the parts I found after disassembly. Anything missing from this leading to loose headset?
Not sure why this is not seated correctly
Is this expander + top cap supposed to go into the head tube directly? I don't under the mechanism of this. So the top cap can be screwed separately but so can the bolt inside of this piece (whatever its name is?)
I couldn't seem to find any instructions on this assembly or figure out the missing piece. The headset seems be called "SI integrated System".
