Triumph TenerifeShould be removable as it's an interference (friction) fit. The silver cap over the fork crown will slide off as well.
What bike is it off?
Thanks Oldfentiger, done that and its come off with no damageMy method is to lightly grip the steerer in a vice and, using a small punch, tap around the bottom of the race. Doesn’t need heavy impacts. Always worked for me.
Triumph Tenerife
Doing a complete restore and resprayWhat is your motive in wanting to "sand it down"?
Prefer to spray it myself, as most of the sandblasters use powder coating which I don't like... Nearly finished with the frame now, just need the finer wet and dry.You might be better off getting it sand blasted. The same company could probably spray it for you as well.
