Bottom brackets and chain lines.
jazzkat
Fixed wheel fanatic.
Hi,
Probably a quick question, but it's a bit beyond my experience.
I'm planning the N+1 build. I'm thinking of using Stronglight track crank which with a 107mm BB, it should give a 42mm chainline (track standard).
I'm planning to use one of these rear hubs; http://www.velosolo.co.uk/756hubcvt.html
Which will give me a chainline of 46mm and allow me to build a non dished wheel.
Am I right in thinking I need a bottom bracket of 115mm i.e. an extra 4mm each side, to get the crank to the correct 46mm?
Thanks in advance.:cheers:
