I have been having a bit of trouble with my fixie.
I now have a Velo orange Threadless Bottom bracket that is really good quality and i don't have any problems with it unwinding.
The axle length is 107mm which is the recommended length for a stronglight 2000 to give me the chain line i'm after. What i find is the drive side of the axle is a little shorter than the non drive side and my crank, when fully screwed in, grinds against the cap.
I have made a shim for it, so it the crank sit a little out from them caps, but i find this is just a temporary measure and i have to clean and create another. I have also filed down the offending bit of the crank to stop the grinding, but it's still a little close.
What i was thinking of doing, and i wouldn't do this with a traditional Bottom bracket, is flip it around so the section that is screwed into the main body is on the drive side.
Just wanted to know what people think of that idea?
Cheers,
Cheers,
