I have an old Soviet-made 3 speed with what is known as a Thompson bottom bracket more common on continental bikes with a 40mm X 70mm threadless BB shell and press-in cups. I want to put this bike back on the road as it's pretty decent to ride and a very practical utility bike and great for pottering about on. However the bottom bracket is knackered.
I can buy the replacement press-in cups and the cones easily enough from Germany or the Czech Republic so I could rebuild it to original cotterpin specification easily enough.
However, for very little more money I could buy square taper bottom bracket spindles or even sealed bearing units. I have a spare single 46 tooth Stronglight chainset so a conversion to sealed bearings would seem a sensible upgrade.
My question is that my current cotterpin bottom bracket spindle is 140mm in length.
Is there any way of me being able to calculate what width of square taper bottom bracket spindle would give me the same chainline? Or will it be trial and error? Obviously as a hub geared bike it needs to be more accurate than on as derailleur bike. A quick look shows 127mm, 132mm and 136mm bottom brackets available and there are probably other sizes if I looked a bit harder. This is the type of thing I'm looking at - https://www.ebay.co.uk/itm/Sunrace-...900271?hash=item2cda69612f:g:-CIAAOSw-b1d6Rhe
