flat-pack
What is the way to tell if the bearings in bottom bracket need replacing ?
I cannot feel any grinding and there are no nasty noises but just feel the unit may need replacing, symptoms are a 'slackness' when climbing hills in between one pedal taking drive over from the other, difficult to explain but a sort of delay, drive is not smooth. Also able to move cranks slightly in towards the frame and away from it, about 4mm at pedal.
Bike is Giant Sedona coming up for 3 years old covered about 8K miles, bracket held in place with notched knurled ring, the kind you use a C spanner on ?
Can I tighten this up ?
Thanks in advance
Graham
Thanks in advance
Graham
