Thanks Chris S Legendary member!Your bike is a Marin so it will have a conventional bottom bracket.
The chainring side unscrews clockwise, i.e. the opposite way to normal.
The other side unscrews anticlockwise as normal.
I’ll give it some wellyThanks Chris S Legendary member!
Drive side is notorious for being difficult to undo, a long handled spanner, or something like a wheel brace will help.I’ll give it some welly
That's why he's a legend 😄Thanks Chris S Legendary member!
In which case I would highly recommend one of theseYes square taper
Nah. You don't need anything that fancy.In which case I would highly recommend one of these
https://sprockets.uk.com/tacx-t4415-splined-tool-for-shimano-taper-8-x-1-32mm-wrench/
though there are simpler more generic things using a screw-in bolt and big washer.
The normal BB tool is an abomination - almost guaranteed to slip with anything problematical.
agree there are other ways - i do have a bolt/washer thing as well.Nah. You don't need anything that fancy.
Put the tool in place. Get the original crank fixing nut and a big washer. Screw the nut in back and the big washer will hold the tool in place. One mighty heave and you can remove nut and washer.
Copper grease is not a lube. Just the opposite. It will wreck your bearings.When you re-assemble, recommend using copper anti-seize grease to lube up with.
