Bottom bracket tools
bunnym0b
Regular
I am replacing the suspect bottom bracket with a Campagnolo Record ( early 1970s). I know I’ll need some tools but am not sure what ones. Are they universal? The suspect one has similar fitting save for the locking ring which has only a single notch in it. I believe it is not a sealed bearing but can’t swear to it until I strip it down.
The bike is from the mid 1980s it’s a Bianchi sprint 28.
i
midlife
Was that breakfast.
I guess you will never use the tools again so woul suggest asking your LBS to remove it. Cheaper and less sweat.
Sharky
Kent
+1 for going to a good LBS.
Campy ones are quite expensive and unlikely to be stocked by your LBS, so don't be surprised if he suggests sealed shimano one. Nothing wrong with a shimano one, unless you want to stick to the brand. Secondly, BB lengths are confusing and easy to buy the wrong one, so another + for going to a LBS, is that they will know exactly which one to use.
If you let the LBS do the job, you won't need any tools, at least until the next time. But I would check that you do have the necessary tool to tighten the cranks bolts should they become loose. The ones in the picture will need a socket or box spanner and needs to be quite thin. A standard car socket is going to be too bulky. Crank bolts nowadays have allen key fittings (8mm?) so just check that you have one that fits in your tool box.
Good luck
  • Like
Reactions: C R
rogerzilla
I have the tools from way back when but not all bike shops will. You'll need to go to a long-established one, as cup and cone BBs have been a rarity for over 25 years.
These are the proper tools; they are big for leverage.
You can remove a BB of this type with a hammer, punch and strongly-attached bench vice if it's not going to be re-used.
On your bike, the cups on BOTH sides probably unscrew anti-clockwise as it is likely to be an Italian threading. Check if the shell is 70mm wide and/or the cups are marked 36 x 24 or ITA.
If the shell is 68mm wide and the cups are marked 1.37 x 24, BSC or ISO, the drive side cup unscrews clockwise.
bunnym0b
bunnym0b
Regular
Thanks for the insight.
Park Tools makes various wrenches.
I’d ask my local bike shop but they have a 4-6 week wait. I’ve taken advice on the one to purchase- it fits the new crankset.
Ajax Bay
East Devon
Just need a 'C-spanner' and a 'double pin spanner' - 3 and 2 in Roger's image above, and good sized adjustable. On an Italian frame (ALAN screwed and glued) I have exactly this Campagnolo BB (well it looks it: mine is late 70s vintage) and came out (and back in) no bother. Hammer and punch would work as well. Any risk of damage can be mitigated by taking due care.
bunnym0b
bunnym0b
Regular
I've ordered the kit and will keep you posted. In the mean time Im going to clean her up and prepare to put on a few Neuvo Record bits and pieces, gears, crankset (the aforementioned bottom bracket) as well as peddles. I've got a set of period Mavic Wheels with small Campagnollo hubs as well as some tasty supple gum rubber boots for my Weinman brakes.
Ill commute to work on this'd see how I get on.
ciao
bunnym0b
bunnym0b
Regular
Was that breakfast.
it was.. why its there i don't know
I have a set of 3 Campag BB tools - cost a fortune in the day, but they were good (used on Shimano kit). Only ever use the one with the 15mm pedal spanner on one end - well I don't - I lent it to my neighbour. The spanner cost more than his pedals. Got them off no messing.
rogerzilla
Assuming it is an Italian BB, the RH cup needs to go in very tight and mild threadlock is better than grease (it prevents corrosion just the same). An insufficiently tightened one will walk itself out on a ride, then you have a problem!
bunnym0b
bunnym0b
Regular
Well it came out and the new one went in no bother. The tools were cheap, and I have a few other bikes to sort out. When the whole thing is done il take a picture.
Thanks for your help. As I said I'd go to my local bike shop but he has a stupendous wait
midlife
Ajax beat me to it lol. Classy looking chainset but the cage needs to be close to the big ring :smile:
