Cyclopathic
- Leicester.
Is there any way easily tell what size a bottom bracket is? I know the length is usually printed clearly on the unit itself (113mm or what have you) but is there any other way to tell?
Also how important is it to get exactly the right size. Could it be the case that a mm either way would not matter in that it would not be detectable in the ride quality. I assume this is to do with chain-line as well as clearance for the cranks on the chain-stays.
All advice happily received and time wasters most welcome.
