bottom bracket repair
Ian H
Ancient randonneur
The cup he's left in is aluminium so it's likely not seriously damaged the steel BB threading. Perhaps he put the lefthand cup in righthand side. If the thread has gone a good frame-builder would ream and sleeve it at a cost. Otherwise you might be able to find a threadless BB cartridge. Mavic used to make one, and I think there are/were others - you'd have to investigate.
Old Plodder
Living at the top of a steep 2 mile climb
If the cup is alloy & the frame is steel, there may only be very superficial thread damage.
(If the frame is quite old, it may even be an Italian BB shell, both sides right hand threads.)
Whatever, if you get it, the link from smokeysmoo, will get you sorted.
