Londoner_85
Hi all.
Images can be found here:
View: https://imgur.com/a/ZlqexTa
I'm hoping to get some help working out what went wrong here and how to avoid it happening again...
I made the (very bad) decision to upgrade my crankset and cranks a few months back and have had a bunch of issues since.
I think what has happened in the pictures is that I didn't tighten the bottom bracket enough so it started to 'undo' when riding which pushed it out into my chainring.. Which then chewed up the bottom bracket, but I'm not 100% sure. I was climbing hills on zwift at the time and it took me a while to realise pedalling was much more difficult then it should have been.
I'm intending on replacing it with Amazon product ASIN B0BPBHVSR9View: https://www.amazon.co.uk/RiToEasysports-Bracket-1-37x24T-Brackets-Aluminum/dp/B0BPBHVSR9
But wanted to check to see if my guess as to what went wrong is correct, or did I screw something up with the rebuild? And also check that is compatible?
Bonus issue: I've now tried 2 separate chainrings and both have had the same wobble - enough to always rub on one side of the derailleur. I now assume this is the attachment of the chainring to the crank? If so I might just disconnected the front derailleur.. I'd prefer to have these 155mm cranks over both chainrings.
