John-Ellis
- Sheffield
Hi Guys and Girls,
I posted before that my crank arms had a bit of a wobble, I thought I fixed this problem but by tightening the bolts. However the crank arms after a while started to wobble again.
Now the noises, creaks and wobbles is all unbearable. So I went to Halfords and got the tools to remove the crank arms and the bottom bracket.
All went pretty well until it come to the bottom bracket, it is not like modern bottom brackets the bearings and spindle are not housed in a cartridge assembly, it turns out my bike has the old fashioned spindle and bearing cup at each end with ball bearings inside each cup.
Now the bearings had grit and allsorts of dirt in them, so I took them out altogether and cleaned them, then I cleaned where they sit in the bike.
So my question now is, do I try and put the old bearings back in, or does anyone think I might be able to buy a more modern cartridge type bearing and spindle assembly.
Thanks
John
Thanks
John
