figbat
Slippery scientist
- South Oxfordshire, UK
I took the slightly loose square taper bottom bracket out of the venerable Trek today - I’d guess it’s the original from 1997 and it came out with no fuss at all. Good start. It is stamped Shimano BB-LP26, 73, 1.37x24.
Then I fitted the replacement, a Shimano BB-UN26, 73mm, 110mm spindle. So far, so good, but when I went to tighten the drive side crank arm it bottomed out on the body of the BB before getting fully tight. When I then measured the protrusion of the spindle from the body of the BB the new one is 2mm shorter than the old one. Both spindles measure at 111.6mm overall.
Is there any way to be sure of getting a BB with an appropriate drive side clearance? Is there a way of checking the tapered hole on the crank arm to see if that has deformed? Any other thoughts?
