BADGER.BRAD
- Shropshire
I have just built a single speed MTB for my lad from an old cheapo bike with very dodgy gears. At first I retained the full cassette and front chain wheel set up ( 3 chainwheels riveted together) But on his request and my pursuit of the simplest cheap bike possible have separated two old cassettes used the spacers and converted the rear cassette to having only one chain wheel.The next job is to replace the front chain wheels with a single chain wheel set up ( without costing any money
) the problem is I have tried four crank assemblies 3 of which put the chain line out so far as to be outside the frame and the original which works but cannot be separated as this would leave me with the large ring and leave the gearing too high. My question is if I were to try and source a suitable crank/single chainset assembly how would I know what taper/crank would work with the bottom bracket I am already using (there seems to be no makings in the bottom bracket !) The bike has now been painted the mattest black I have ever seen and looks so ugly it's beautiful ! I'll try and add a photo tomorrow.
Thanks for any help
Brad
) the problem is I have tried four crank assemblies 3 of which put the chain line out so far as to be outside the frame and the original which works but cannot be separated as this would leave me with the large ring and leave the gearing too high. My question is if I were to try and source a suitable crank/single chainset assembly how would I know what taper/crank would work with the bottom bracket I am already using (there seems to be no makings in the bottom bracket !) The bike has now been painted the mattest black I have ever seen and looks so ugly it's beautiful ! I'll try and add a photo tomorrow.Thanks for any help
Brad
