I have a Trek 1.5C road bike. Still has the original crankset (FSA Vero Compact).
Last time I had it serviced at LBS (Oct 2012) I asked them to look into a creak in the bottom bracket. They replaced it (it was still the original and I'd done about 2,500 miles on it). When they removed it, there was a bit of rust discolouring on the inside of it. They replaced it with a Shimano of some description.
I am getting a similar creaking again now. It's only when out of the saddle and applying pressure to the pedals; going up a steepish climb, for example. I am wondering if it's the same problem as before so was looking into bottom brackets. However it seems very confusing over all the different types available.
I have never attempted to replace a BB before so could just take it to LBS, but would like to learn a bit more about maintaining my bike. I tried to measure the frame but it seems BBs can be 68mm or 70mm (ie 2mm difference) and it wasn't easy to measure the frame or get the tape flat to it.
I was thinking I might replace the BB with something better, but not entirely sure what will fit and if I would need to replace the chainset as well. Could I just upgrade the BB and chainset? Say I was to get an Ultegra BB and chainset. Would that be compatible with my chain, cassette etc?
How do you find out what BBs are compatible with your bike/chainset?
