biking_fox
- Manchester
I've been looking for a new frame and one I happen to like has a low bottom bracket height which the builder claims means it shouldn't be used with thin tyres.
"frames are designed for a 1.75 tyre, as the tyre gets
smaller the bottom bracket gets nearer the ground, when cornering with too
low a b/b the pedals can touch down on the road.
Is there really that much difference between a 1.75" tyre and 23mm in terms of wheel depth? I've only ever ridden on road tyres and have no idea how deep a 1.75" tyre is.
Considering I normally corner with the low peddle up anyway to prevent this, can I ignore a reputable frame builders advice - they really should know more than I do - and put a 23mm tyre on anyway.
