Bottom bracket 650b Boardman 2017 mtb
Drako
Hi
I got a Boardman 650b comp Mtb (2017)...
My bottom bracket is going. Wich would be the best model and size to replace it?
Kindly
Ajax Bay
East Devon
Like this one? https://cyclingshop.org.uk/boardman-comp-2017-mountain-bike-27-5-650b/
SRAM X5 chainset? Like this one? Amazon product ASIN B01GOJLK5EView: https://www.amazon.co.uk/SRAM-X5-10-Speed-Crankset/dp/B01GOJLK5E
If so, a BB30 BB. Your brief request suggests that your local bike shop may be a sensible port of call.
  • Like
Reactions: C R
Drako
Hi
Hi and thank you for replying.
Just attached some pictures of my mike & some characteristics.
Can you just confirm if that's the right bracket & where can I order it from, as my local shop can't provided it atm 😔
Ajax Bay
East Devon
Your chainset looks to be a SR Suntour XCM. And the listing shows it's a square taper BB (not a BB30 which the X5 would need).
Maybe this is like yours: https://www.tredz.co.uk/.SR-Suntour-CW-XCM-D-22-36T-MTB-Chainset_89726.htm
The best square taper BB is a UN-55. Will be 'English Thread'. You need to get the dimensions right and the two critical ones are the width of the BB shell - would guess at 73mm - normal for MTBs, and the spindle length (more difficult but maybe 113mm - that sort of figure anyway). If you're fitting this yourself, you can take off the cranks and measure both dimensions.
For assurance you must measure these - I would not buy till I had.
The 73/113 seems out of stock in some places but here's one: https://winstanleysbikes.co.uk/shimano-bb-un55-bottom-bracket
Thats not square taper, it's got a hollow axel.
Pic of the non drive side please. Being Suntour, it might use Shimano Hollowtech, but could be GXP.
Jason1488
Regular
Sorry to bring up the past but I have the same bike as this and my bottom bracket has completely fell apart .can some one send me the correct link on what bracket to buy please .
rogerzilla
Can you use Google? A Deore BB was suggested above.
However...you will need a special tool to fit it, as well as some grease, allen keys and probably a mallet. It may come with instructions but, if not, you will need to look them up. It is possible to ruin parts or have the LH crank fall off if you don't do it properly.
Assuming the new poster has the same chainset. Suntour XCM AX.
Google fu is lacking in this padawan.
Boardman did swap and change specs on some bikes due to stock.. My FS Pro came with upgraded SRAM Guide RS brakes rather than the Avid stuff - snapped it up.
Jason1488
Regular
Google is wack !!! And I also did search the debore bb wasn't no help at all ..
I do have the suntour chain set and I have ordered to bb and they have both gone back due to the size and fitment .
I did order a Meroca Bottom bracket which does fit 68/73mm threads but this was wrong ..
