wheres_my_beard
- Norwich
Can anyone recommend a device to allow me to mount a bottle cage on my frame? It has no holes to allow direct mounting.
Exactly that kind of thing (nice find). But would you reccommend it?
If you aren't that fussed about the slight cosmetic difference the best device is in fact bottle cage bosses fitted to a frame the same as the ones that are missing from yours, you can get this done with no respray.
Drill two holes, fit the rivet-nuts with the correct tool, if you have a good LBS they will be able to do it.
Well short of two bottle cage bolts...If I wasn't so contrary that would make perfect sense.
Unfortunately I do like to be able to completely remove accessories from my bike when I don't need them.
Thepaininspain... do you mean this one?
http://www.decathlon...acket-17250470/
