Bootom Bracket Stuck! HELP!!
Spooly90
ive got a bottom bracket that i cannot get out ! its not rusty but has been sitting in a shed doing nothing for about 3 years ive got the right tools ive soaked it in wd40 and other penetrating oils ive even heated it with a torch but it will not budge with all 15 stone of me pushing on it and i am turning it the correct way ..... :sad:
itchyrider
Aka Chris
london N16
No.:biggrin:
are going opposite the rotation of the pedals?
Oldlegs
Frogs are people too.
Norwich
They can be a real sod.
Try taking the wheels off, lock the removal tool on with a bolt / bit of metal, get the frame firmly set on some grass and really heave.
This worked for me - in the end.
S
Spooly90
the tool i have is the same as a socket so i cant bolt it on lol. my hands are very soar !
im gonna leave it over night see if the wd40 helps it
Globalti
Don't waste your time with penetrating oil, it doesn't work until you've started some movement.
Go to the shed and find a biggish bolt, a couple of nuts and some washers. Remove the bearings from inside the race. Work out which way you need to turn the race and set up the bolt with the washers and nuts either inside or outside the BB so that turning the head of the bolt the right way will tighten everything up. Then get a feck-off spanner (engineering term) and turn the bolt. The race will come out sweet as anything.
The problem is that the two metals form a bond and no amount of WD40 or heating will work.
I'd stick with the non-drive side which undoes normally.
There are two ways of getting them undone - but only use if the frame is not valuable.
1. get something longer to attach to the tool and then whack it as hard as you can( do not hold back). The sudden shock can free the BB.
or
2. Place the tool in a vice and then turn the frame - pure force can free the BB
please note these are not guaranteed to work
S
Spooly90
i dont see how i can bolt the tool to the bb as its round and then i cant grip it with anything to turn it
Oldlegs
Norwich
I'm making assumptions on what bottom bracket you have but if the cranks bolt on you can use the bolt and any bit of metal with a hole in it to hold the socket tool firmly in place. If it comes off the splines when you are really pushing you end up punching the ground very hard.
boydj
Paisley
You need a bench vise. Clamp the spanner / bb tool in the vise, then hold the frame so that the tool engages properly in the lockring and then turn the frame. Best Christmas present I ever gave myself - BBs, cassettes, and anything else that's hard to shift. The additional leverage you can get really gets things moving - just as long as you are turning in the right direction.
