Bolt-cutters
Chris S
Birmingham
What exactly are bolt-cutters used for, apart from stealing bikes?
Are there any circumstnces in which anybody would want to crudely cut a bolt?
chewy
Devon
Often used to cut seals on the likes of shipping containers, for one!
Gareth
I own a pair of 36 inch long Bolt croppers, and they are invaluable for cutting round steel bar up to 16mm rebar and rough cutting flat steel from 3 mm X 10mm up to 10mm X 20 mm which I use a lot of in the ornamental metal work that I do.
bauldbairn
Falkirk
Bolts - when you've loosened it enough to get the nut jammed on the damaged threads and don't have time to hacksaw it off. Also cutting the length of a bolt or screwed rod if it's too long - because the bolt cutters cut from both sides they don't bend the steel. They're like a small portable workshop guillotine
Padlocks - on toolboxes(in engineering workshops) when you've lost your key.
Cutting steel rods(dowels), metal straps / fabrication etc.
They're very handy for a multitude of engineering jobs in inaccessable confined spaces too - it was inevitable someone would use them for criminal purposes.
I also used to have a small set of oxy/acetylene gas bottles(gas axe) to take out on site - they would have fitted in a rucksack and what the boltcutters couldn't cut - they could.
slowmotion
Quite dreadful
lost somewhere
Gas axe?:whistle:
Respect! I will ask Mrs slowmotion for one of them on Valentines Day.
Sod the chainsaw... :thumbsup:
Ticktockmy
I have used them to trim the excess off brake and gear cables.
A Tad overkill dont you think..LOL
I own a pair of 36 inch long Bolt croppers, and they are invaluable for cutting round steel bar up to 16mm rebar d-locks and rough cutting flat steel from 3 mm X 10mm up to 10mm X 20 mm armoured cable locks which I use a lot of in the ornamental metal work that I do.
Of course I do officer ! :thumbsup: :whistle: :biggrin:
subaqua
What’s the point
Leytonstone
brilliant for quick removal of copper cable to decommisioned switchgear when doing stripout work.
like big side cutters.
