Hi,
I've been planning a 'lockdown' project to rebuild a Boardman SLR 9.8 frameset - which was originally spec'd for SRAM ETap (ie wireless) with a mechanical groupset. Not sure if its because the oem build is wireless, but its missing the 3 frame inserts for gear cable stops - 2 downtube for front/rear derailleur and rear chainstay derailleur exit hole. It also lacks any top tube frame brake cablestops for rear break - but I can live with that and run brake housing full length through frame... The same bike/frame is available as a mechanical build (SLR 9.2/9.4) so I assume frame inserts are used and available somewhere.
However after literally months of email pingpong trying to get these sourced via halford/boardman bikes I still getting nowhere trying to get the part. I have tried using 'generic' Jagwire frame brake/gear cable stop, but unfortunately the diameter is fractionally too big for the holes in the boardman frame. The jagwire inserts seems to be about 7mm (maybe 7.2) diameter across the narrow end (not the wider flange end that is eternal on the frame). But the holes in frame are just under 7mm - 6.7 6.8mm.
So wondering if anyone could advise of anywhere that might do a frame insert that would fit - either a generic one or the boardman specific one - at this stage I'm not worried as like I say Ive been waiting since lockdown to start the build but can't really do it if cant source the frame inserts/cable guides...
Any help much appreciated!!.... Cheers....
