Boardman road comp 2012 till present day
cyberknight
I am restating this thread as it seems my original photos have been "lost " by the file host and to remove non related posts .
Stock photo from the shop
  • Model Year: 2012
  • Material: Lightweight alloy triple butted, full smooth welding with mudguard clearance
  • External cable routing (internal brake cable)
  • Double bottle cage mounts
  • Clamp on front derailleur
  • Replaceable forged aluminium rear dropout
Fork Details:
  • Material: Superlight full carbon, tapered steerer, mudguard clearance
Wheel Details:
  • Mavix CXP22 on Formula hubs with SST black spokes
Groupset:
  • Speed: 20 gears
  • Brake/Shift Levers: SRAM Apex
  • Chainset: FSA Gossamer, compact 50x34 (crank length varies according to frame size)
  • Bottom Bracket: FSA MegaExo
  • Rear Derailleur: SRAM Apex
  • Front Derailleur: MicroShift
  • Brake Calipers: Tektro R730, cartridge type rubber insert
  • Chain: KMC X10
  • Cassette: SRAM PG1050
Finishing Kit:
  • Handlebar: cboardman, 31.8mm. Bar width varies according to frame size
  • Bar Tape: White
  • Stem: cboardman, 31.8mm. Stem length varies according to frame size
  • Seat Post: cboardman, 31.6mm x 300mm
  • Saddle: cboardman
  • Tyres: Vittoria Zaffiro, 700 x 23c
Pedals:
  • Supplied with basic flat pedals although Wiggle recommends using dedicated clip-in pedals and shoes to get the most from your road bike
Warranty:
  • 3 year frame warranty, 12 month parts warranty
Weight:
  • 20.21 lbs
cyberknight
cyberknight
Update to r 501s
NorthernDave
Never used Über Member
Nice bike.
I've got a 2015 Road Comp and can't praise it enough.
Mines still pretty much standard, apart from replacing the worn Zaffiros with Continental Ultra Gator Skins and adding a pair of bottle cages from Planet X.
Booyaa
Went off them :smile:
I liked, made it look a bit different.
