Hi All,
A friend wants to buy a bike and they’ve asked me for advice. In terms of use it will be fair weather cycling only on flat terrain (on road only) and just used for short journeys of a couple of miles or so. I don't think that they intend to fit a rack or anything else. Now I know that just about any bike, as long as it’s mechanically safe, will be absolutely fine for this type of use.
However they’ve told me what they’re intending on buying and given that they’ve asked what I think about it I’ve offered some alternative thoughts but I just wondered if anyone else has any ideas of other bikes out there to consider so I could pass on the ideas?
It’s a guy who is probably about 6ft 1 or 2 and they’re looking to spend somewhere between £350 & £500
They’ve said that they’re dad & brother-in-law have this bike and they’re happy to buy the same because they really like it. Therefore I’ve said that if they like it and they’re going to use it then go for it.
http://www.halfords.com/cycling/bikes/hybrid-bikes/boardman-mx-sport-bike
However I’ve recommended that they test ride it and also test ride some other bikes to see what they think in comparison. If they can’t get the Boardman at its current discounted price of £400 and they have to pay £500 then I’ve suggested that they take a look at the following:-
http://www.halfords.com/cycling/bikes/hybrid-bikes/boardman-hybrid-comp-bike
or
http://www.halfords.com/cycling/bikes/hybrid-bikes/boardman-hybrid-comp-bike-2016
In my opinion, given that they won’t be doing any off-road stuff, the suspension fork not needed at all and so I’ve suggested that they look at the Boardman comp instead because it has a rigid fork.
Given that it’s only being used for short journeys on flat roads I don’t think that they need 20 odd gears. I thought that as an alternative this Whyte Whitechapel with a 1x drivetrain would be a good bike to test ride and compare to the Boardman.
http://www.cyclesuk.com/en/Whyte-Whitechapel-2016/m-52457.aspx
At the same time I thought that they should see if they could test ride some single speed bikes, such as the following, if possible.
Charge Grater
https://www.evanscycles.com/charge-grater-0-2017-singlespeed-bike-EV290676
Kona Paddy Wagon
https://www.evanscycles.com/kona-paddy-wagon-stubby-bar-2016-singlespeed-bike-EV302316
Pinnacle Dolomite
https://www.evanscycles.com/pinnacle-dolomite-singlespeed-2017-road-bike-EV264164
Or given that it’s only going get occasional use for short journeys my suggestion was to look out for what comes up second hand. My first option was this but I don’t think they were too keen. You never know with second hand until you can actually view & checkout the bike itself but the thing that has maybe put me off this (and I could be completely wrong here) is that it looked to me like this might have originally been a drop bar bike which has now been fitted with flat bars and I thought that this might have a negative effect on the fit given the geometry.
http://www.bicyclelinks.org.uk/bike/raleigh-royale/
Thanks for any thoughts on this.
John
or
Charge Grater
Kona Paddy Wagon
Pinnacle Dolomite
John
