lulubel
- Malaga, Spain
My partner has recently expressed an interest in getting a Boardman CX, which will be mostly used on road, with a little bit of light off-road use. Her ideal option will be to have 2 sets of wheels, one with skinny tyres for pure road rides, and one with wider tyres that are better suited to tracks and some of the really bad so-called roads around here. The wheels that come with the bike would probably be fine for the latter.
The wheels that come as standard have Alex DP17 rims, which I gather are 17mm wide, so 700x25 tyres would be pushing the limit of those particular rims. They're also "entry level" rims, and I've promised her a set of light, fast wheels to go with her new bike. Bearing in mind that the frame has disc brake mounts only, is it going to be possible to buy a wheelset with lightweight rims that will take her prefered 700x23 tyres?
Presumably I could build a set with disc hubs and standard road rims with a braking surface, but it would be nice to have a set of wheels that "matches" the bike. Also, I'm guessing disc rims are probably a bit lighter because they don't have the braking surface.
