Hopefully someone may have seen this before ....
My son has knocked his BMX handlebars out of alignment, but I can't work out how the stem works to put them back! It's not the usual "4 bolt clamp", there's a single 8mm hex head bolt through a square which looks to compress onto the handlebars to fix (see pics). The only other bolt is for the headset. When I take out the 8mm head bolt I still can't move the bars.
Is it a case of loads of GT85 then take out the square piece? Or is there a magic trick here?
Thanks, Paul.
Thanks, Paul.
