No it shouldn't have had any effect as it specifically deals with friends settings for user profiles.
Have you changed the blog settings yourself, perhaps done it and fogotten you'd changed it, or maybe even done it without realising (I'm fairly sure you should have your own independent control over that setting)?
If not, I may need to check the global settings.
Cheers,
Shaun
