Bleed kit for Shimano grx 600 brake lever
Alma
Member
What bleed kit do I require ?
I have these
si_c
Wirral
It's the same bleed kit as Shimano Road, so you'll need the adapter for the funnel (which should have come with the bike) and if you are doing a full bleed then you'll need the syringes and oil.
I use the Epic Bleed Solutions kit for my road bike.
A
Alma
Member
It's a new bike build, I don't have the adaptor will I be able to buy this and will it have name?
A
Alma
Member
Sorry just seen the link in chat, is the silver adapter in that kit the adapter I need?
If I bought that kit I would have everything I need?
si_c
Wirral
Yep, the silver adapter is everything you need. It comes with brake fluid, and all the kit to do a full end to end bleed of the system.
If you are doing the bike build from new, chances are it will come pre-bled so you may not need to do much anyway.
