Cubist
Still wavin'
- Ovver 'thill
I have a pair of Blackburn System X8 SL lights, but as is so common the battery pack no longer charges. It isn't covered by warranty, so I split it to examine the contents and discovered it contains three pink coloured batteries wired in series. I can't find any technical data to tell me what voltage these are, but they are marked up with a letter C, then KH8FJ22 and underneath that what appears to be a string of numbers, 028729, on another is 028730 and the other is obscured by the protection strip. Googling these doesn't help.
The charger kicks out 12.4 volts.
So, if I wanted to wire myself a new pack, which cells should I use? If the pack contains three pink cells to make 12 volts, does that mean I have to find 4 volt Li-Ions, or would four 3 volters do it?
