TomHammersley
Hello all,
So, on Friday I had a puncture. I swapped out the tube for my patched-up spare, rode home, not a problem.
I thought I'd swap the patched one out for a new one on monday night. In went the new one, pumped it up, and it blew out. I thought I'd just pinched it or something when I installed it, so I carefully put another one in, pumped it up, and it *seemed* ok.
Came back to the bike the next day, and the rear wheel (where I'd swapped the tube) was flat. The new tube had a hole in it. I took the tube out and the tyre off, checked everything for debris, nothing to be found.
Since then, I've put in 4 different tubes of various types, both old and new, always being sure that I hadn't pinched them, and making sure there was no debris around. Every time, the tube blew about 100-110 psi, with the tyre feeling notably more difficult to inflate around that point.
I'm at a loss. I can't find any debris inside the wheel to explain the problem, having removed the tube & tyre multiple times and cleaned it out. Every time it blows out about the same pressure, so it seems there is something at play. I've checked the rims, can't see any problems there, no burring or anything.
Any ideas? I'm at a loss, and it's on my best bike too, so alas I cannot currently ride it!
The wheel is an 08 Khamsin, Pro Race 3 tyres, and a mixture of continental, specialized and random unbranded tubes.
Thanks
Thanks
