jamin100
- Birmingham
Roughly after how many miles / years would you give your bike a FULL service?
My CX is just over a year old and done 1500 miles. There's no major problems with it as such aside from a few creaks maybe but just wondering if i should think about getting it serviced yet.
One of the local shops to be is offering the following for £100 inc VAT but plus any parts needed etc
I don't know enough about bike maintenance or have the tools/time to learn so am wondering if this is a good option?
12 months guarantee on any parts fitted
- FULL STRIP DOWN TO FRAME AND FORKS.
- CHECK WHEELS SPIN FREELY AND TRUE ACCORDINGLY.
- CHECK AND ADJUST BRAKES FITTING NEW CABLES (AND FURTHER PARTS IF REQUIRED).
- REMOVE, DEEP CLEAN, REFIT AND LUBRICATE CHAIN.
- CHECK AND ADJUST GEARS FITTING NEW CABLES (AND FURTHER PARTS IF REQUIRED)
- REMOVE BOTTOM BRACKET , STRIP, CLEAN AND REPLACE OR RE GREASE BEARINGS AND THREADS.
- STRIP HEADSET, INSPECT FOR WEAR AND REPLACE OR RE GREASE BEARINGS.
- STRIP WHEEL HUBS, INSPECT FOR WEAR AND REPLACE OR RE GREASE BEARINGS.
- CHECK TYRE PRESSURE AND INFLATE TO CORRECT TYRE PRESURE OR CHANGE TUBES.
- ALL PARTS ARE REMOVED, CHECKED FOR WEAR, CLEANED AND RE GREASED OR REPLACED AS REQUIRED.
- CYCLE IS RE ASSEMBLED WITH ALL NUTS AND BOLTS TIGHTENED TO CORRECT TORQUE SETTINGS.
- CARRY OUT A FULL ROAD TEST.
