Viper5
Regular
- Welwyn Garden City
Can I have a recommendation for a decent set of lights plesse. I don't think the £15 ones being promoted by the young sales assistant are up for the job.
If you have an iPad or similar, there is a nifty Cateye Beam App to show the different models. Also available as a PDF.Good point I guess be seen but then also a good visibility.
Just been looking at the Bontrager ion 700 . I'll look at the cats eye.
What's best for the rear?
Thanks
Not really, as if you point them high enough to illuminate the full road width a decent distance ahead, the top of the bright spot is too high and dazzling other road users, which is illegal, so you need to buy a decent lens as well as a uk plugs, possibly better battery and so on... which means you're quickly approaching the price of a decent StVZO light and have wasted a lot more time assembling it all. Lumens are bunk if they're directed at the wrong place.To see where you're going. A chinese import cree 500lm is the best value for money.
Not necessarily, but all plastic clip-on/clip-off things seem to get a bit brittle when it's really cold. DAMHIKALl the much more expensive cateyes etc break after a year or so as the plastic snaps.
That is not generally true. There are at least two incompatible front mounts and I suspect there's three but two lights are currently in use so I can't really checkI also like the fact that the mounts fit all CatEye models (front).
Well, they do fit across the Opticube and Volt models, I think the Volt range is the most popular at the moment.That is not generally true. There are at least two incompatible front mounts and I suspect there's three but two lights are currently in use so I can't really check![]()
What do they mean "charging socket for optional charger"? Does it mean it can be usb charged as well as battery powered?I got a B & M Ixon IQ Premium from Rose recently (link). Very impressed with it as it puts out lots of light in a wide, flat-top beam pattern just like dipped beam on a car, so it's not dazzling to other road users.Ideal for my country lane evening commute.
