Bike in Berlingo Query
youngoldbloke
Will I be able to fit my 1750mm long road bike standing upright in the back of a Berlingo M - the 5 seater - 2018 on? Does anyone have measurements of the load space with the back seats down? TIA
DCLane
We can fit road bikes on either size with one / all the seats down as the front wheel drops into the passenger footwell on the 2008 model (Peugeot Tepee) son no. 2 now has. They're then tied down using tie straps over the seat holding metal clips.
youngoldbloke
youngoldbloke
https://www.google.co.uk/
Will give you this result....
Citroen Berlingo sizeBerlingo MBerlingo XL
Maximum load length (mm)1,8172,167
Maximum load height (mm)1,2361,243
Maximum load width (mm)1,5501,550
Width between wheelarches (mm)1,2301,230
Thanks for that. Where did you find it, what search terms did you use? I've spent far too much time googling and never come up with such specific measurements. Useful sites I found were RiDC, and how-many-bags-fit.com, but their figures differ somewhat to those. The load length will also vary depending on whether the upright front passenger seat is slid forward or not.
Marchrider
not only does it fit in, you can also sleep with it
Dogtrousers
Kilometre nibbler
Useless answer. In 2016 I was on a ride where we took three or four bikes (I think four) to the start in the back of a Berlingo and as I recall they were all upright.
youngoldbloke
youngoldbloke
"2018 Citroen Berlingo M 5 seater load space dimensions".
I believe the figures you posted refer to the van load space and not the car/MPV. They are not necessarily the same. Does anyone have a 5 seat 2018-on M MPV they could actually measure? (I believe the earlier ones were slightly shorter).
youngoldbloke
youngoldbloke
Thanks for above answers. To resolve my question once and for all, I was recently able to actually measure a 5 seat 2019 Flair 'M' (XTR - 3 individual rear seats) and with a rear seat folded flat and the front passenger seat slid fully back and upright the load space is 1755mm long, and with the same seat slid fully forward the distance is almost 1900mm. The front passsenger seat also folds flat to give even more length if required.
