bike fitting
adam23
hi i live in oxfordshire and would like to get my bike professionally fitted just to be sure
its all OK.
can anyone recommend a few good places local to me or a bit of a travel if its worth it
thanks
Adam
Sleeping Menace
UK
Before you dump the money into a local fitting, give this a go:
Competitive Cyclist Fit Calculator
It's by far the best one I've seen, and if you take your time, follow the directions exactly, it will get you 90% of the way to an ideal fit. You're always going to tweak slightly, whether after a calculator or professional fitting, but this one tends to be very very good ..
http://anotherdooratthe.endoftheinternet.org
Cycle related blog entries, including a few 5 minute reviews:
http://anotherdooratthe.endoftheinternet.org/category/cycling/
A
adam23
Afl2 I don't know if they would mate, they good a good range of bikes there but not really into fitting tbh.
I will try the calculator approach and then tweak it if it needs to be done
MacB
http://anotherdoorat...theinternet.org
http://anotherdoorat...tegory/cycling/
I would second this but get someone to help with the measurements and do them a few times to be sure. Interestingly, or at least for my dimensions, for a road bike this site gives very accurate results as well:-
http://www.prodigalchild.net/Bicycle6.htm
and little in the way of measurement needed
