big off, wheel question please
Bicycle
I hope you're OK.
An LBS would know about the wheel. It looks a bit Donald, but the bends are big-radius and look smooth.
The only time I've binned a wheel was after having to remove it and whack it on the ground to straighten it enough to crawl home with snapped-open front V-brake. Until I impact-treated it on the ground, it wouldn't rotate in the forks. It was fine on the way home (if a bit Charlie Chaplin) but the LBS declared it beyong economical repair as I'd added new buckles to the original ones.
My understanding is that most bent rims are worth a go, but as I get mine done by a shop, you might want to read other replies... :rolleyes:
