bahamas
- New Providence Island, The Bahamas
Are there advantages to wearing bib shorts as opposed to regular cycling shorts?
Big advantage of bibshorts is that you have no elasticated waistband pressing on your bladder.
bib shorts are made for the job, they won't ride up in the legs, and they won't slip down at the top of the back. They feel comfortable, knowing they're not going to move and keep you covered up.
All of which, in my experience, is also true of conventional shorts.For long rides yes they are an advantage as the padding stays in the right area.
...which in turn means that this is also not a problem when you're wearing ordinary shorts.The major disadvantage is when you need to have a number 1 (or 2) - especially a roadside one.
The other advantage of conventional shorts is that bibshorts are built for a particular combination of height and waist size. Unless you've got one of he standard ratios (I don't) they'll never fit.Big advantage of bibshorts is that you have no elasticated waistband pressing on your bladder.
For long rides yes they are an advantage as the padding stays in the right area. On short rides of an hour or so, I didn't really feel any difference
Bibs keep you lower back warmer as well.![]()
