Bib Tights
aJohnson
Bury, Manchester
Downward said:
what do I wear over them ??
Nothing?
gavintc
Southsea
Downward said:
Hi
It all depends what you are doing. :evil:
If you are cycling, as these tights have a pad, nothing over or under. Most tights you will buy in Britain come without the pad and you wear them with your bib shorts underneath.
gavintc
Southsea
What you wear on your top half is completely up to you and weather dependant. Personally, in winter I wear a helly (or equivalent) underlayer and a cycling top.
Tynan
e4
I'll be starting my third winter in my Merstons, £25 on offer at the time, good gear
GrasB
Nr Cambridge
Usually a light weight short sleeved jersey with arm warmers & a wind/shower proof jacket if needed. I tend to find bibbed lycra are a fair bit warmer on the back than non-bibbed, this mostly negates the need for heaver jerseys or a base layer.
