Specialeyes
- Essex
Back in this thread, I mentioned that I was going to switch my Bianchi X4 to Campagnolo C-Record from Shimano Dura-Ace. I'm not a die-hard 'you-must-have-Campagnolo-on-an-Italian-thoroughbred' chap usually, but this one, like David Ginola's hair, was worth it.
Well, it got complicated to the point I began to question the wisdom of the switch and contemplated refitting the Japanese groupset.
When I stripped and began assembling the Campag components, I discovered that the Shimano headset design is 14mm neater than the Italian one. This meant that the steerer tube was cut 14mm too short for the headset top nut to engage the threads: 172mm of tube vs 186mm of headset.
I pondered for a while over the wisdom of 'cutting and shutting' such a critical component: what would happen if it gave out at speed? etc. Then, finally decided that the rest of the bike is held together in exactly the same way, so why should it.
So, I took the bits to a local frame repairer and restorer (Tim at Gunn & Co.) who fabricated a beautiful extension plug, fractionally tapered and a snug fit for the centre of the tube. It's one of those jobs that once the tube is cut, you just have to press on, no turning back!
He firstly dry-fitted it in an alignment jig then soldered it into the middle of the tube...
and finished the whole thing beautifully!
So I could then rebuild the bike in Campagnolo mode. First time I've ever set up Delta Brakes and you know what? They weren't too much of a faff, and work surprisingly well, considering how much folks describe them as the pinnacle of form over function.
So, when the weather turns crap for the next month and we have nothing but cold wet weekends, you can blame me and my new summer bike!
