Best tool for chain ring bolts?
Shut Up Legs
Down Under Member
I'm trying to tighten the outer bolts on a large front chain ring, i.e. the bolts that are hollow, with a groove on the outer end that faces towards the crank. I was using the Park Tool CNW-2 tool, but it's bloody useless, because the bolt keeps moving when I use an Allan wrench to tighten the matching inner bolt. Any suggestions?
classic33
Leg End Member
How tight are the actual nut & bolt compared to one another?
All I've ever used is an old screwdriver in the slot to hold the inner(hollow) bolt in place.
Shut Up Legs
Shut Up Legs
Down Under Member
Never mind, I managed to tighten them. I need to find more suitable tool for the hollow bolts, though.
