Best spray paint.
coco69
North west
I am doing a little project...aluminium frame with carbon forks....ive got loads of info on how to do it just need recomendations for a good out of the can spray paint.
Thanks
adamhearn
screenman
I hate to say this but I consider Halfords laquer to be amongst the best single packs out there, in fact all their rattle cans work well if you have prepared properly, and of course apply correctly.
I taught spray painting for a while and have been lucky enough to have tried and tested a lot of brands.
Personally even with my skills and equipment I would let somebody else do it.
YahudaMoon
Car paints are fine if you use twin packs, aerosol are single pack and are not as durable by a long shot.
Yeah but the question is 'Whats the best paint' for a bicycle, the best frame builders use enamel
I don't see why you'd use car paint, enamel paint is very thick and hard wearing, I guess thats why its the best choice for bicycles
Saying that, this is my knowledge from many years back, maybe things have changed?
screenman
Your last line is I feel correct. Although I am sure some stuck in the dark ages may still use enamel there are more using twin packs.
screenman
2 pack paint is pretty hard wearing and with "car paint" you can have any colour/finish you want.
Do you use 2 pack? Not easily available in aerosol, personally I have full water based scheme here at home.
adamhearn
Not on bicycles; done some panel spraying. The aerosol is pretty expensive at £18 + P&P but my thought was that you can get whatever colour scheme you're after then clear it with this and you have a pretty decent finish.
screenman
Water based paint is 2-pack (paint & hardener), isn't it, just using water instead of thinners?
No it is a water bourne pigment , you do thin it but not with water funnily enough. No hardener in it as it dries by the water evaporating off. You do though have to use a twin pack laquer over the top.
Even so called solid coloured cars will be a wb base coat followed by a laquer coat.
Water based is not good for you to breath.
