best position for descending
cyberknight
Someone done a study and worked out which position is the fastest for descending , turns out froomes position is not the best .
http://www.cyclingweekly.com/news/r...-329475?utm_source=Facebook&utm_medium=Social
AAEAAQAAAAAAAAxaAAAAJDMzYWVmMDBlLTU5YmMtNDIxOC05MTM0LTBkMmRkNGQ5NThmZA-e1494325136224.jpe
mjr
"Based on the assumption that all riders either aren’t pedalling while descending or are pedalling with the same amount of power" - so which of the three "faster" than the "Froome" position can you actually pedal in? I'm not sure you can in any of them.
I think even Sagan uses the "Froome" position while pedalling and then pushes back into "Top tube safe" when coasting, as seen here in Richmond:
View: https://www.youtube.com/watch?v=Td9kXwI9_fc
Hugh Manatee
I favoured the left hand holding the to of the bars right next to stem. Flat back and the right arm behind the back.
Jody
Stubborn git
When the situation permits I use the Pantani. Difficult on a MTB with nobblies but can still get up to nearly 50. You can tell the difference qith wind resistance as soon as you sit back up. I don't like the look of Froome or top tube "safe". Looks completely the opposite to safe to me.
cyberknight
cyberknight
These are tuck positions when you run out of gears. "Back Down" has got me to 60mph. The others are bloody scary.
Yup , me too , sometimes i use a variation with the hands on the hooked over the tops ala TT position if its a straight descent .
Tin Pot
Pfft, call those aero positions?
smutchin
Cat 6 Racer
The Red Enclave
Back when I was about 14-15, I had a neat trick which was riding the bike from a position seated on the rear rack. No hands on the bars, of course. I was able to pedal from that position. And steer. Maybe Pantani would have been even faster with a rack on the back of his bike.
I've tried the "Top tube safe" position but it definitely does not feel "safe" to me at speed. My preferred descending position is somewhere between "Back horizontal" and "Back down" depending on how flexible I'm feeling. I try to look where I'm going though, not at my front wheel like the dudes in the illustrations.
