Bending a seatpost (intentionally)!
simon.r
Person
Nottingham
A bit of an odd one this, so any help appreciated.
I'd like a 25.8mm swan neck seatpost with a 'traditional' top (like this): http://www.ebay.co.uk/itm/SNAKE-BIK...N-/201500511185?&_trksid=p2056016.m2518.l4276 but they only seem to be available in 22.2mm or 25.4mm.
I can't find a shim from 25.8mm to 25.4mm or 22.2mm, so I'm wondering if it's feasible to bend a steel 25.8mm seatpost? (Something like this http://www.ebay.co.uk/ulk/itm/252257037092 ) A coiled spring insert, heat and brute force? Whaddya reckon?
Get a 25.4mm one and I will send you some 0.2mm thick shim to use with it. We have lots of different thickness shim at work. You will be able to cut it with scissors.
tyred
Ireland
Cut a shim from a Coke tin.
If you are bending one, I'd use a steel one rather than alloy as it;s less likely to crack and find someone with a pipebender.
simon.r
simon.r
Person
Nottingham
I did think about the Coke can shim (I've done it in the past), but this is on a new frame and I'm reluctant to risk damaging it (even though I reckon the risk is low).
Agree about steel rather than aluminium.
simon.r
simon.r
Person
Nottingham
I have to ask, why set back?
Just to get my position on the bike more comfortable. I have a left knee that doesn't bend beyond about 90 degrees and normally use a pendulum crank ( http://www.getcycling.org.uk/details.php?id=460 ). This is for a sit up and beg bike, which I reckon fitting a setback post to, along with a shorter left crank (already fitted) will sort me out.
RichardB
Slightly retro
West Wales
Drinks cans make ideal shims - right thickness, soft and malleable metal, easy to cut. From an engineering point of view, nothing wrong with it. I've used them on handlebars and seat posts, never a problem. Just make sure it's nicely trimmed so that it doesn't show, and especially doesn't show words like 'Special Brew'.
Personally, I wouldn't dream of bending a seatpost, even a steel one. The thought of what could end up happening if it snapped makes my eyes water.
