Beginner at 48!
Andynewbee
New to cycling. Have purchased Carrera road bike to try out hobby and get fit/meet people. Have discovered this site and you nall seem to be clued up on the subject and having looked further i know i should probably not have brought the bike i have but it serves my purpose for now and my bank balance. Nice to be part of your forum and i will welcome any support you may be able to offer particularly with regard to what type of pump do i go for as there seem to be many and the last one i had 30 years ago doesnt resemble the new types regards beginner
bazza59
Andy
welcome
I have only been cycling for a few years and my carrera vanquish is my good bike.
Re Pump - I would recommend getting a track pump ( anything between £5 from lidl / aldi to £30 from your local bike shop). This will allow you to get the tyre pressures up to 100-110 psi easily. Also get a "small" pump for mounting on the bike, I have a Blackburn (£20), some of these can get up to the higher pressures but are thought of as getting you home after a P*.
baz
nosherduke996
Newdigate,surrey
Andy, i hope you enjoy the cycling.I have been cycling for twelve weeks now at the age of 54 and the difference in those twelve weeks have been amazing.Lost over a stone in weight and doing about 100 miles a week which includes mounting biking on thurs nights.
jack the lad
Welcome
I took up cycling at about your age too. I think we are quite a common breed. It was a bit of a shock how much had changed since I were a nipper too! 'Cross bars' are call 'top tubes' now, apparently - I bet it's the yanks!
Best bit of advice I can give from my experience of buying bits of bike kit is not to economise. More than any other area of consumer goods you do seem to get what you pay for in cycling, or perhaps put the other way round - cheap stuff is more likely to be rubbish than a bargain and you spend more in the long run.
I think I'm going to contradict myself immediately though. You can buy an old fashioned conventional pump from Wilkinsons for £1.49 that works perfectly well as a get you home job. For home use get a stirrup pump to get tyres up to high pressure. Brands like Park Tools, Blackburn, Topeak and Specialised are all pretty good and spend around £25 or more. If you want a better pump to carry with you, look for the same brands, again you need to be looking at £25 or so, anything under a tenner will be a waste of money (but I hope someone on here will be able to contradict me). Blackburn's 'Airstick' I think is often recommended - will pump up to high pressures and keep working for a long time. They come in different lengths to fit the size of your bike frame. I've got a Blackburn mountain bike pump, which is fine. MTB pumps have shorter fatter barrels to shift more air into fat tyres, but don't usually get to such high pressures as the road bike ones. I still prefer using a conventional pump though and a firm called Zefal makes some good ones if you haven't got a Wilko's nearby.
Carrera bikes are good value for money and fine bikes. Halfords staff & quality standards are variable though - hope you got a good one that was well set up!
A
Andynewbee
Thanks for all your advice and support its nice to know there is a wealth of experience out there for me to call on. I,ll take on board all yor suggestions - thx
Globalti
Don't buy the cheap Hafrauds track pump - it's too fat to enable you to pump a road bike tyre up to 100; you'll need muscles like a gorilla. Topeak is best.
GrumpyGregry
Here for rides.
welcome. I entered my fourth incarnation as a cyclist, this time in the form of a tourer/commuter, last year at 47. quite a bit thinner now, quite a bit fitter, quite a bit more at ease with myself as a result. lots of good advice in here and some great people.
enjoy
gbb
Peterborough
Welcome andy...
if it suits your purpose and bank balance, then you hav'nt made a mistake buying the Carrera.
I havnt had one myself, but have had a similar quality bike....it'll serve you well if you look after it :laugh:
From what i've read, they're not bad bikes....
Sittingduck
Somewhere flat
Hi
I was advised (wisely) to get a Topeak Joe Blow Sport 2 from Evans. Truely amazing, compared to the Halfords track pump that was okay for pressures up to about 80psi. For road bikes and 120psi tyres - I would say it's a revalation!
SD
Randochap
Senior hunter
Welcome, young lad! Well they say you never forget, huh?
The challenge now is to get cycling fit and improve your skills.
Pump: The only pump worth owning IMO is the Topeak Road Morph. You can see it in use here, where you'll also learn how to deal with a puncture roadside, if you're rusty on that procedure.
There's lots of other tips and info @ VeloWeb as well.
Cycling is a great life!
Welcome, I started cycling 4 months ago at the age of 47 too, without the help of the people on this site doubt would have got this far. Started doing 8 mile trips now doing 50 miles with relative ease.
Keep cycling and enjoy!!
