CyclingStone
I am highly appreciative if someone has nput on this one. But please refrain from telling me what a headset, fork or even bike if you don't know. I have always thought that having the actual numbers is the best thing you can have but today I have been told to measure it and all kind of things. But I have the numbers! So maybe you know.
It says: "
P16(⌀52x7x45°) " on the UPPER bearing which means P16=double sealed 52=outer diameter 7=width and 45 is the degree. I get this. I also found this from the manufacturer. This is alibaba crap which came with the bike, it roasted pretty quickly. I want some bearings from someone else than alibaba and I therefore need to know if I can replace them and most importantly with that.
Size:1-1/8,1-1/2 integrated headset
Crown:7075/T6 CNC (OD ø33X45)
Cartridge Ball Bearing:CBB-418
OD ø41.8X45X45
OD ø52x45x45
Top cover:6061/T CNC with rubber O ring
Material:6061/T6 CNC machined top cover
Steel crown Race
Type:For Carbon Fork"
Thanks! But please do not tell me that I need to take off the old ones and put on new ones if I want to replace them.....
My question: Do I need to find a upper bearing which is 52x7x45 with 45degrees and that's it? Is 45/45 the same as this? Because there are a lot of (36/45degrees) on the internet.
Edit: I am sorry about this long post but it sadly seems like you need to state these things because I have only got strange answers the whole day about this topic. If someone could educate me so I maybe can understand what these numbers mean. Because like I said not knowing yourself and still getting it right seems impossible when it comes to bikes. Either I can replace it or I can't if I can I want to know with WHAT.
It says: "
OD ø41.8X45X45
OD ø52x45x45
Steel crown Race
