presumably as each other... but you raise a valid pointSame size as what?
Not an arsy question, but there are so many options in either type that you simply cannot answer that question.
While it might not strictly be the correct answer, the best answer is 'no'.Are the bearings in threaded and threadless headsets the same size ?
Yes. I should have been clear I was referring to modern threadless headsetsDon't think proper bearings (eg for threaded headsets) are anything but spherical @SydZ . The balls certainly aren't "stamped" but do come in different diameters and may come caged or not.
Who said anything about "replacement"?
We need Q2 to progress.
My headset of choice back in the days of quill stems. I never wore one out and I don't think I ever had to even adjust one. I used to regard ball bearings as the work of Satan before threadless came along.Some thread headsets are needle / roller bearing
http://bikeretrogrouch.blogspot.com/2013/10/roller-needle-bearing-headsets.html
Would that be the Stronglight A9?My headset of choice back in the days of quill stems. I never wore one out and I don't think I ever had to even adjust one. I used to regard ball bearings as the work of Satan before threadless came along.
The last one I remember using was made by VP. I'm not sure if they are still around, but I remember they also made pedals and probably other bits and pieces too.Would that be the Stronglight A9?![]()
