DCBassman
 - The lumpy far South West
Noticed this morning on pre-ride check that the rear wheel had noticeable side-to-side play. Now, I understand how cups and cones work, but how in the name of (insert preferred sky-fairy name here) do you lock the drive side cone against anything? There's no way to hold it. I've looked at many youtube videos, but they all seem to merely explain how the basics work, which I understand.
The only way I can see to do this is to remove the axle completely, tighten the drive-side cone against its various outer bits, then rebuild and do the actual bearing adjustment from the non-drive side.
It's a standard Shimano hub on an R500 wheel, nothing remotely weird.
Your (fairly urgent) help appreciated!
