BB30 maintenance/replacement
Twilkes
My BB30 is clicking and creaking, possibly now that the temperatures are rising again as it was fine over the winter but a bit clicky last summer.
I already have a replacement BB30 that only has about 150 miles on it that was removed because of reasons, and the crank is a SRAM Rival 22 which I think has an octocrank (?), I've taken the drive side off before but never removed the other side which has the axle attached to it.
I've done most things on a bike, replaced derailleurs, cup and cone hubs etc, but never messed with a bottom bracket.
So what tools would I need? i've read about various gauges and pulls and push tools and not sure what is absolutely necessary.
Is it worth buying them over getting an LBS to do it, i.e. is it a skilled job to get it set correctly or do they seat themselves fairly easily?
Cycleops
Accra, Ghana
You’ll need a couple of tools to remove and replace the bearings which shouldn’t be too expensive. Might be worth getting the LBS to do it if lead time is not long.
This is a good video by Hambini taking you through the process.
View: https://youtu.be/ecT_6vjjjGQ
Twilkes
Twilkes
Thanks for that - so I need fairly specialist tools to remove and replace the BB, looks like this will be £50+ unless I'm not finding the right things. Seems a lot for a spindle and some different sized nuts and shaped washers!
I think my LBS charges £30 if that for BB (and that’s London pricing). Pressfit Need to be fitted properly to avoid more creaking and if it does creak again, they can sort again
Twilkes
Twilkes
Yeah I think when I had it done last it was £25, but I think I want to do it just to understand what's going on with it in case any problems come up again; I've had mixed experience with LBS mechanics. I'll consider installing an adapter when this current crankset bites the dust, but until then I'd like the option of doing it myself.
figbat
Former slippery scientist
I know it is not the ‘correct’ way but when I did the BB30 on my Cannondale Synapse I drifted the bearings out with a punch and hammer and then drifted the new ones in using the old bearing as a driver and keeping as square as is possible by eye. No issues afterwards, all quiet and smooth. It cost me only the price of the new bearings.
I have subsequently picked up a headset press which is just a threaded rod with handled nuts and washers either end and use this for any similar bearing press needs.
Twilkes
Twilkes
Had you/have you had any clicking/creaking, and did you use any bearing compound when fitting either the bearings or the cranks?
figbat
There was creaking before I did the replacement and I used only a light film of general purpose grease for assembly.
