alci4
- birmingham
Just wondered how much I should expect to pay to get my bb30 greased on my new cannondale Road bike at a local bike shop. Thanks for any help
On a NEW Cannondale it should be FOC, take it to the shop you bought it from? How many miles and what make you think it needs greasing, they are sealed units. You can open them but not really supposed to
I thought (hoped as I have just bought a Cannondale) that they had sorted the problems with the PF BB30?
I have a Boardman CX, which sounded like it was running dry after just 500 miles and was, my understanding is that a standard BB30 its easy to have mud and water ingress and Cannondale are fitting PF BB30 which if you look and a similar appearance to hollowtech II BB a slight outboard part which offers protection.Greased? It shouln't need greasing other than on the front surface between the end cap and the bearing. DIY!
Undo the bolt holding the crankset on (it is usually a self extracting bolt so will push the crank arm off as you undo it), pull it out, end caps off, clean it all out, smear grease on front of bearings, end caps back on, crankset back through, tighten bolt, it is literally a 1 bolt, 5 minute job!
What is wrong with BB30?
I take it back, it is a PF30! Looks like all the 2014 Supersix have these.I'd heard of that Boardman issue. Never heard of this PFBB30 thing though.
Having ridden BB30 for years now (ATM I have one Vision/Cannondale BB30 bearing set and one SRAM bearing set), I can't say I have noticed any problems with water ingress etc. That said, my crankset is swapped twice weekly during the racing season as it gets moved between my road bike and TT bike every weekend so gets lots of TLC.
I would either follow Roberts instructions, or expect around £15 - 20 labour costs, guess many bike shops have a minimum of half an hour labour charge. How many miles have you done? Only keep asking as it is unlikely to be the actual sealed bearing, more likely grit in and around making the noise.hi its a cannondale caad 10
had the same problem on my last one
the wife got it for me from sunset mtb so not that easy to pop back with it so gonna have to take it to a lbs
+1If it is happening when you are free wheeling, look elsewhere for the issue IME!
Sage advice. Remember that CC and YouTube are your friends in all matters of fettling.I suggest you learn some basic mechanical skills, else you will spend loads on simple jobs over the years!
HUGE +1. Don't do it, there must be an LBS option you can use.Also, I would not let Halfords shop monkeys anywhere near a bike of mine!
cheers guys
have only done 40 miles on it so far but i had this same thing on my last caad 10
when i stop peddling at speed you can hear the ticking
halfords have said they will do it for a tenner
i know it is prob such a simple job for you guys that tinker a lot but i am one of those people that turns a two min job into a two hundred pound repair job i will thread or strip something 100%
