BB Square taper size
taximan
senex crepitu iuvenis cordi esse
I think I need to replace my bottom bracket square taper bearing and not sure what size to order. I imagine the shell size will be 68mm but i don't know the spindle length but it will need to run with a triple chain-wheel. can anyone advise me please.
Depends on the chainset. Sheldon Brown has an extensive list.
Here you go:
https://www.sheldonbrown.com/bbsize.html
C R
Worcester
If you are keeping the chainset then the spindle will need to be the same size as the one you have. If getting a new chainset the specifications will tell you which size spindle to use.
In any case, a good read of Sheldon Brown as suggested above should help you work out what you need to consider.
